RB V 15.0;
My report is very simple. There is almost zero code in it.
It has a RichView Advanced RTF item. The underlying data type is VarBinary(Max)
1. If I run a report where there is just a plain text no problem.
2. If i run one with an embedded image, then I get Canvas does not support drawing.
3. If I try to run a report with some Embedded SRV controls then I get access Denied message Error code 5 followed by a shower of ListIndex out of bounds and AV’s.
Thanks very much in anticipation.
SRV and Report Builder
