Pretecting areas.
TonyBlom
Pretecting areas.
Post by TonyBlom »
I wish to protect areas of text. The idea is to create a template with SRV Controls on it including Memo etc. I want to protect most things except for the Controls. Is this possible ?
Thank you
You can protect the whole document by assigning editor.ReadOnly := True.
Also, you can protect paragraphs, see Options property of a paragraph style: http://www.trichview.com/help/idh_tcust ... tions.html
However, protected paragraphs can be deleted as a whole (unless they have undeletable items)
You can protect a text item, see Protection property of a text style: http://www.trichview.com/help/idh_tcust ... ction.html
You can protect a non-text item from deletion, see rvepDeleteProtect property: http://www.trichview.com/help/idh_type_ ... perty.html
TonyBlom
Iterating through SRV controls
Post by TonyBlom »
Could you give me a short example of how to iterate all the SRV controls on a Doc.
My idea is to make the Document itself read only, but allow the user to interact using SRV controls.
To do this I need to iterate through all the controls setting them read only.
ALso I will want to bind some of the SRV controls to DB field content.
A short example how to iterate through the SRV controls would be very helpful.
Thank you.
