I have RichView data in a blob field.
I need to load it into a TFrxRichView component of FastReport.
How can I do it? All I can see now is unreadable characters. I suppose I need to convert the blob data to RichView format...
Thank you
How can I print ScaleRichView from Fastreport?
Sorry, we still did not implement support for FR.
There is an unofficial version: http://code.google.com/p/theunknownones/
But we did not test it.
My progress
I'm amazed a simple example hasn't been directly provided.
I did it years ago by simply rendering it to a picture and including the picture in the report. that was too limited since we were then restricted to just one page. amazingly, it was enough for quite a while.
I've been making a linkage between the two that is more full-featured.
The code below has RV generate a metafile for each page. it considers that the first page may be of a different size than later pages and also that the last page may not be the full height.
after this, you need to bring them into FR.
procedure TForm1.MakePix;
function _MaxPageHeight(iPage:integer):integer;
if iPage=1 then
Result:=300 // this value will be from FR's Engine.FreeSpace value
Result:=500; // just a test value
const
icWidth=300; // just a test value
iPage:integer;
bmp:TBitmap;
rh:TRVReportHelper;
Metafile : TMetafile;
MCanvas : TMetafileCanvas;
rh:=TRVReportHelper.Create(self);
rh.RichView.Style:=RVStyle1;
rh.RichView.LoadRVF('doc.rvf');
bmp:=TBitmap.Create;
rh.Init(bmp.Canvas, icWidth);
bmp.Free;
iPage:=1;
while rh.FormatNextPage(_MaxPageHeight(iPage)) do
Metafile := TMetafile.Create;
Metafile.Width := icWidth;
Metafile.Height := _MaxPageHeight(iPage);
// GetLastPageHeight only NZ on last page
if rh.GetLastPageHeight>0 then
Metafile.Height:=rh.GetLastPageHeight;
MCanvas := TMetafileCanvas.Create(Metafile, 0);
MCanvas.Font.PixelsPerInch := PixelsPerInch;
rh.DrawPage(iPage, MCanvas, False, Metafile.Height);
MCanvas.Free;
MetaFile.SaveToFile('c:\tmp\' + inttostr(iPage) + '.wmf');
inc(iPage);
