reset list numbering
AlexKraft
Post by AlexKraft »
Hello!
Sorry for my bad English.
I have a problem with cleaning numbering squeaks in RichView.
RichView insert text in a numbered.
ms:= TMemoryStream.Create;
s := GetRTF;
ms.Write(s[1], Length(s));
ms.Seek(0, soFromBeginning);
table.Cells[0,0].LoadRTFFromStream(ms);
RichView.AddItem('', table);
But if run this code a second time, the numbering of the text you want to continue numbering value early insertion. In a method RichViewEdit RemoveLists (False) which resets the numbering, but this method RichView component is missing. Can I reset the numbering of the list is the component RichView?
Sorry, I do not understand, do you want to continue numbering when inserting RTF for the second tome, or do you want to reset it?
AlexKraft
Post by AlexKraft »
On the form, there are two components and TRichView TRichViewEdit.
In Trichvieschedit entering text using the numbered squeak, for example:
  • 1. words ...
    2. words ...
    3. words ...
    n. words ...
This text is sent to TRichView, here's the code:
ms: = TMemoryStream.Create;
  RichViewEdit.SaveRTFToStream(ms, False);
  ms.Seek (0, soFromBeginning);
   ms.Free;
Further repeated paste text using a numbered list and instead to get in TRichView two different numbered lists:
  • 1. words ...
    2. words ...
    3. words ...
    n. words ...
    1. words ...
    2. words ...
    3. words ...
    n. words ...
it turns continue numbering:
  • 1. words1 ...
    2. words1 ...
    3. words1 ...
    4. words ...
    5. words ...
    6. words ...
I know there is a method in TRichViewEdit RichViewEdit.RemoveLists (False) which resets the numbering and allows her to start from the beginning.
But RichView is no such method, as you can reset the numbering RichView?
