My customer created a new set of icons which I used in the ActionTest demo.
I used jpg, png and bmp.
The Undo and Redo buttons were completely grey when inactive with jpg and bmp.
The png images were worse: they had black area around them.
Can't the TToolButton show the images well, or is there something with the pictures?
I also used the Silk Icons which you recommend on your page but in inactive state they are also grey squares.
Thank you
Icon change problem
The standard TToolBar generates old-fashioned inactive images.
Solutions:
- create a set of nice disabled images (using a graphic editor), add them to an imagelist and assign this imagelist to ToolBar.DisabledImages
This approach is used in ActionTest demos
- use a thirdparty toolbar that can generate modern looking disabled images, such as http://www.silverpointdevelopment.com/sptbxlib/
By the way, I recommend using our images (from ActionTest demos) instead of Silk icons, because:
- our images already have disabled versions;
- our images include icons for all main operations
- Silk icons have low contrast, they look good only on a very light background.
Solutions:
