Is first save?
starhu
Is first save?
Post by starhu »
I need to log the save of the file only if it is the first save or save as.
- So the user creates a new document and save it -> I need to log it
- The user types in something and saves it -> I don't need to do anything
- The users clicks on Save As -> I need to log it
The problem is that in the rvActionSave1Saving method I cannot distinguish if it't the first save or not.
I tried comparing
srvActionsResource.rvActionSave1.GetDoc(MainForm.ActiveEditor.RichViewEdit).FileName and the input FileName because I though that srvActionsResource.rvActionSave1.GetDoc(MainForm.ActiveEditor.RichViewEdit).FileName would be the old file name but they are the same.
Thank you
Use TrvActionSave.OnDocumentFileChange event
starhu
Post by starhu »
Thank you, I tried it, but it never enters into OnDocumentFileChange event, no matter if I save, edit or close.
This event is already assigned in code of ActionTest demos.
It is assigned in FormCreate, and probably this assignment overrides yours.
In ActionTestTabs it is used to display a file name on a tab.
starhu
Post by starhu »
Thank you, it works now.
