If I double click on Header / Footer, ScalerichView will show the editor part of it.
Even if I set SRichViewEdit1.RVHeader.ReadOnly := True;
Can I disable double click on header and footer?
Thank you
Can I disable double click on Header / Footer
Yes, there are options to hide headers and footers, but no options to prevent activation of editing (however, you cannot change them if they are readonly).
Currently, the only solution is moving the caret back to the main editor in OnChangeActiveEditor event:
procedure TForm3.SRichViewEdit1ChangeActiveEditor(Sender: TSRichViewEdit;
ActiveEditor: TRichViewEdit);
if (ActiveEditor=Sender.RVHeader) or (ActiveEditor=Sender.RVFooter) then
Sender.StartEditing(srvrveMain)
I think yes - you need to assign this event to new editors.
In the original ActionTestTabs demo, properties of a new editor are assigned in the procedure TForm3.AddEditor.
You can add there:
You can add there:
srve.OnChangeActiveEditor := ActiveEditor.OnChangeActiveEditor ;
