My customer requires to use another extension. I set everything in RVAControlPanel.
When I open such a file e.g. something.brd then I get this error:
Error loading file
Possible reasons:
‐ format of this file is not supported by this application;
‐ the file is corrupted;
‐ the file is opened and locked by another application.
If I rename to .rvf, it can open again.
Thank you
Error loading file with another extension
Please give me step-by-step instructions how to reproduce this problem.
I copied readme.rvf as readme.brd, and made the following changes in the ActionTestUni project's RVAControlPanel1:
DefaultExt='brd'
DefaultFileName='Untitled.brd'
RVFFilter='RichView Files (*.brd)|*.brd'
RVFLocalizable=False
Everything works as expected, I can open readme.brd
DefaultExt='brd'
I found out what causes the problem:
If I use :
srvActionsResource.rvActionOpen1.CustomFilter := 'brd docs|*.bds';
then I can open the "bds" extensions well.
But if I use this:
srvActionsResource.rvActionOpen1.Filter := [ffiCustom]; // so as only bds extension would be available
I get an error message...
Thank you
If I use :
But if I use this:
Thank you
If you use CustomFilter property instead of renaming RVF format, you need to process this file of types yourself, in RVAControlPanel.OnCustomFileOperation event: http://www.trichview.com/help-actions/t ... ration.htm
