Hypertext works in TRichViewEdit and crashes in TRichView
Jim Knopf
Post by Jim Knopf »
I integrated hyperlinks as shown in the demo 'create hyperlinks'. Works fine there in the TRichViewEdit. If I load the same text inti TRichView, I get an access violation in CRVData because he never gets a valid item (here:
if GetItem(i).GetBoolValueEx(rvbpJump, RVStyle))
procedure TCustomRVFormattedData.GetJumpPointLocation(id: Integer;
  var RVData: TCustomRVFormattedData; var ItemNo: Integer);
var i: Integer;
    LRVData: TCustomRVData;
    RVStyle: TRVStyle;
    StoreSub: TRVStoreSubRVData;
    item: TCustomRVItemInfo;
  RVStyle := GetRVStyle;
  RVData := nil;
  ItemNo := -1;
  for i := 0 to ItemCount-1 do begin
    if GetItem(i).GetBoolValueEx(rvbpJump, RVStyle) and
       (GetItem(i).JumpID+FirstJumpNo = id) then begin
      RVData := Self;
      ItemNo := i;
    item := GetItem(i);
    LRVData := TCustomRVData(item.GetSubRVData(StoreSub, rvdFirst));
    if (LRVData<>nil) then begin
       repeat
         if LRVData.GetRVData is TCustomRVFormattedData then
           TCustomRVFormattedData(LRVData.GetRVData).GetJumpPointLocation(id, RVData, ItemNo);
         if RVData<>nil then begin
           StoreSub.Free;
         LRVData := TCustomRVData(item.GetSubRVData(StoreSub, rvdNext));
       until LRVData=nil;
     StoreSub.Free;
In TRichViewEdit are about 56 items, in TRichView only 23. In TRichViewEdit the result is true at the 13th item, in TRichView never. Regardless of UseHypertextStyles in RTFReadProperties is set or not.
Do you have any idea what's going wrong?
Can you send a project reproducing this error to richviewgmailcom?
Jim Knopf
Post by Jim Knopf »
Sent you a first shot by mail
Jim Knopf
Post by Jim Knopf »
Sorry, my mistake: I used two different TRichViewEdits in declaration and code ...
