cube
Post
by cube »
How do I prevent table splitting / page break inside a table?
I'm adding a number of small tables in a document and I do not want to habe a pagebreak inside a table. It should be between two tables.
Regards
Rainer Hamann
Post
by Sergey Tkachenko »
The simplest way is excluding rvtoRowsSplit from table.PrintOptions
(however, this option cannot be saved in RTF and DocX)
cube
Post
by cube »
Now a part of the table is not printed. Is it possible to recognize, if a page break has do be inserted before that table?
Regards
Rainer Hamann
Post
Insert this table in another table 1x1 without borders.
Assign table.Rows[0].KeepTogether = True for this outer table.
(this method works as you expect in RVPrint, not in ScaleRichView, because ScaleRichView does not support pagebreaks inside cells yet)
