Paste without protection
Marcer
Post by Marcer »
I copy to clipboard an RVF text included a protection : [rvprStyleProtect, rvprModifyProtect, rvprDeleteProtect, rvprSticking, rvprStickToTop, rvprDoNotAutoSwitch]
Is it possible to remove the protection included in RVF Text on pasting?
Best regards
Marius
The current version does not have an option for this.
You can paste in a hidden editor, modify its text styles, then insert to the main editor. You can use OnPaste event.
procedure TMyForm.MainEditorPaste(Sender: TCustomRichViewEdit;
  var DoDefault: Boolean);
  if not hiddeneditor.CanPasteRVF then
  hiddeneditor.Clear;
  hiddeneditor.DeleteUnusedStyles(True, True, True);
  hiddeneditor.Format;
  hiddeneditor.Paste;
  for i := 0 to hiddeneditor.Style.TextStyles.Count-1 do
    hiddeneditor.Style.TextStyles[i].Protection := [];
    hiddeneditor.SaveRVFToStream(Stream, False);
    Stream.Position := 0;
    maineditor.InsertRVFFromStreamEd(Stream);
    Stream.Free;
  DoDefault := False;
Marcer
Post by Marcer »
Thanks Sergey!! It's functionnal!!
Best regards!!
Marius
