Replace picture with double click, keeping object properties
mverbeek
Post by mverbeek »
I have a .RVF-file with a (temporary) picture. I want the end-user to replace this picture by double click on the picture, keeping object properties (visible size and spacing)
It should be a short cut to the File Dialog you get by richtclick on the picture, select Object Properties and then press the button Change.
It's necessery to set the Initial Directory!
ANY SUGGESTIONS?
I have tried by using the ActionInsertPicture
srvActionsResource.rvActionInsertPicture1.OnExecute := nil;
srvActionsResource.rvActionInsertPicture1.InitialDir := 'c:\';
srvActionsResource.rvActionInsertPicture1.MaxImageSize := 100;
srvActionsResource.rvActionInsertPicture1.Spacing := 5;
srvActionsResource.rvActionInsertPicture1.Execute;
srvActionsResource.rvActionInsertPicture1.OnExecute := srvActionsResource.rvActionInsertPicture1Execute;
but then i need to get the Object Properties of the double clicked picture to set
I can not find out how
ANY SUGGESTIONS?
I do not recommend using rvActionInsertPicture, because, as you noticed, it does not keep existing properties.
I suggest using your own TOpenPictureDialog and SetCurrentPictureInfo method.
mverbeek
Post by mverbeek »
Sergey
Thanks for the quick reply!
Do have some sample code (I am new to RichView)
NB I use ScaleRichViewEdit....
Sorry for the delay.
It's simple, because a double-clicked item becomes current, so you can use CurItemStyle, GetCurrentPictureInfo and SetCurrentPictureInfo methods.
procedure TForm3.SRichViewEdit1MouseDown(Sender: TObject; Button: TMouseButton;
  Shift: TShiftState; X, Y: Integer);
var Gr: TGraphic;
    VAlign: TRVVAlign;
    Tag: TRVTag;
  if (ssDouble in Shift) and
    ((SRichViewEdit1.ActiveEditor.CurItemStyle=rvsPicture) or
     (SRichViewEdit1.ActiveEditor.CurItemStyle=rvsHotPicture)) then begin
     SRichViewEdit1.ActiveEditor.GetCurrentPictureInfo(Name, Gr, VAlign, Tag);
     if OpenPictureDialog1.Execute then begin
       Gr := RVGraphicHandler.LoadFromFile(OpenPictureDialog1.FileName);
       if Gr=nil then
         Application.MessageBox('File loading error', 'Error', MB_OK or MB_ICONSTOP)
         SRichViewEdit1.ActiveEditor.SetCurrentPictureInfo(Name, Gr, VAlign, Tag);
RVGraphicHandler is defined in RVFuncs unit (for TRichView versions prior to 14.13) or in RVGrHandler unit (for TRichView 14.13+)
mverbeek
Post by mverbeek »
Sergey,
Thanks for the reply!
I accomplished it. Below the source, maybe handy for other users....
Best regards!
procedure TFrmEditor.SRichViewEdit1RVDblClick(Sender: TCustomRichView;
  ClickedWord: TRVRawByteString; Style: Integer);
    AName: TRVAnsiString;
    Agr, Agr2: TGraphic;  AVAlign: TRVVAlign;  ATag: TRVTag  ;
    directory: String;
    setWidth, setHeight, orgWidth, orgHeight: Integer;
    setFactor: double;
  if (Style = rvsPicture) then
    if pPernumb > 0 then
       directory  := PATIENTEN + GetPatientDir(IntToStr(pPernumb));
       OpenPictureDialog.InitialDir := directory;
     end
      directory  := TEMPLATES;
    if OpenPictureDialog.Execute then
      SRichViewEdit1.ActiveEditor.GetCurrentPictureInfo(  AName, Agr, AVAlign, ATag );
      SRichViewEdit1.ActiveEditor.GetCurrentItemExtraIntProperty( rvepImageWidth , setWidth);
      Agr2 := RVGraphicHandler.LoadFromFile(OpenPictureDialog.FileName);
      orgWidth  := Agr2.Width;
      orgHeight := Agr2.Height;
      setFactor := orgHeight /orgWidth ;
      setHeight := Round(setFactor * setWidth) ;
      SRichViewEdit1.ActiveEditor.SetCurrentPictureInfo(  AName, Agr2, AVAlign, ATag );
      SRichViewEdit1.ActiveEditor.SetCurrentItemExtraIntProperty( rvepImageWidth , setWidth, true);
      SRichViewEdit1.ActiveEditor.SetCurrentItemExtraIntProperty( rvepImageHeight , setHeight, true);
