convert MIME to RTF
Wizard2007
convert MIME to RTF
Post by Wizard2007 »
Good day.
I want convert MIME into RTF, but on this forum i find only examlpe for convert RTF to MIME. Have you any example for this type of convertion?
MIME file contains multiple files combined in a singe file.
When used for HTML email, it contains HTML, may be images, may be an alternative text representation of HTML, may be attached files.
We do not have a procedure for extracting HTML and images from a MIME file. You need to do it yourself or using thirdparty libraries such as Indy or CleverComponents.
We do not have an Indy example, sorry.
For CleverComponents, see http://www.trichview.com/forums/viewtopic.php?t=4123
As for RTF, simple use SaveRTF method.
Wizard2007
thank you i will try it.
