HI. I wish to download and install the latest. Also, my TRIchView components have become a bit messed up with different versions of the Demos to the Components and so on.
IM a licensed user - licensed to Verion 15
Id like to clean out al the old and install with the latest
I have Delphi 7 and Delphi XE2 installed,
1. Is there an article that describes how to do the upgrade ?
2. How can I check the version of my RV components ? (I have SRV also)
Thanks,
Tony
UPGRADE process
1) http://www.trichview.com/install-faq.html
2)
- TRichView: RVStr.pas, RVVersion constant, such as
The version is written in readme.txt too.
When installed, the version is displayed in TRichView and TRichViewEdit components at design time.
- RichViewActions
The version in RVActionsReg.pas, in the line like
The version is written in history.txt too.
- ScaleRichView
The version is at the beginning of SclRView.pas, SRV_VERSION constant, like
When installed, you can see value of TSRichViewEdit.Version property in the Object Inspector.
2)
RVVersion = 'v14.12';
- RichViewActions
reg.WriteString('Actions_Version', 'v4.5.6');
- ScaleRichView
SRV_VERSION = 'v5.9.3';
