How to disable limiting bounds of rv contents when printed
lwinter
Post by lwinter »
We are using the RichView editor to paint its contents into a device context (metafile) which in turn is placed into a diagram. The contents printed to the metafile are clipped when the contents exceed a certain size.
We need to be able to print unclipped RichView contents to metafile regardless of the size / extent of the contents.
Q:
How can setting / applying of bounds be disabled when printing / painting to device contexts/ metafiles?
Thanks!
-- Lutz
Clipping? As far as I remember, TRVReportHelper does not do any clipping.
Only TRVPrint does, if ClipMargins property is True.
