Margins doesn't obey in TDBRichView
alexandreq
Post by alexandreq »
Hello Sergey
I dropped a TDBRIchView on a form and I have in it a background image.
I change the margins so that my text can be display on the delimited margins, but the top and the bottom margins doesn't obey, only the right and the left is ok.
As you can see in my bellow draw image, the first box is the TDBRichView component, the second box is where the text must be display with top and bottom margins.
The right and left margins is ok, they obey correct. The bottom doesn't and when the text appears, it appears out of my bottom margin. The top only works
to display it, but when I scroll the text with my mouse, the top margins doesn't work anymore.
Is it a bug?
___________________________
|    ______________________   |
Alex[/img]
Sorry, I do not understand the problem.
Please send me a simple project reproducing the problem to richviewgmailcom
alexandreq
Sent
Hello Sergey
I've sent you a small project, did you get it?
No. May be it contained an exe-file, so gmail rejected this email?
alexandreq
Hello Sergey,
I've sent you once again, there isn't any exe in the zip file.
I've sent in your svt email and richview email too, please, let me know if you got it.
thanks
Received (on the both addresses). I'll try to test it tomorrow.
alexandreq
ok, thanks
Probably you expect that margins are not scrolled with a document, but reduce a scrollable area. This is not correct, margins are scrolled too, and the whole client area of TRichView is scrollable.
Details by email.
