Can I merge 2 RTFStrings on a non visible TRichviewEdit
LuckySpacy
Post by LuckySpacy »
// Here is the working code
procedure TfrmTest.Button8Click(Sender: TObject);
  s: string;
  List : TStringList;
  m    : TMemoryStream;
  RichViewEdit1.Style := RvStyle1;
  s := MergeRTF3(_Artikel.getLangBezRTF, _KuText.getLangTextRTF); [color=red]// Different to Button7Click[/color]
  RichViewEdit1.Clear;
  List := TStringList.Create;
  m    := TMemoryStream.Create;
    List.Text := s;
    List.SaveToStream(m);
    m.Position := 0;
    RichViewEdit1.LoadRTFFromStream(m);
    FreeAndNil(List);
    FreeAndNil(m);
  RichViewEdit1.Format;
// This works fine
function TfrmTest.MergeRTF3(aRTFString1, aRTFString2: string): string;
  List: TStringList;
  m   : TMemoryStream;
  rv  : TRichViewEdit;
  ItemNo, Offs: Integer;
  rv := RichViewEdit1;  [color=red] // The different RichViewEdit is on the Form [/color]
  // Load RTFString1 in RichviewEdit
    List.Text := aRTFString1;
    m.Position := 0;
    m.Position := 0;
    rv.LoadRTFFromStream(m);
    rv.Format;
    FreeAndNil(List);
    FreeAndNil(m);
  // Move Caret to the end
  ItemNo := rv.ItemCount-1;
  Offs   := rv.GetOffsAfterItem(ItemNo);
  rv.SetSelectionBounds(ItemNo,Offs,ItemNo,Offs);
  // Insert RTFString2 in RichviewEdit
    List.Text := aRTFString2;
    m.Position := 0;
    m.Position := 0;
    rv.InsertRTFFromStreamEd(m);
    rv.Format;
    FreeAndNil(List);
    FreeAndNil(m);
  // New RTFString
    m.Position := 0;
    rv.SaveRTFToStream(m, false);
    m.Position := 0;
    List.LoadFromStream(m);
    Result := List.Text;
    FreeAndNil(List);
    FreeAndNil(m);
This is what I want, but this is not working, the style is lost
procedure TfrmTest.Button7Click(Sender: TObject);
  s: string;
  List : TStringList;
  m    : TMemoryStream;
  s := MergeRTF2(_Artikel.getLangBezRTF, _KuText.getLangTextRTF);
    List.Text := s;
    m.Position := 0;
    FreeAndNil(List);
    FreeAndNil(m);
// This don't work.
function TfrmTest.MergeRTF2(aRTFString1, aRTFString2: string): string;
  List: TStringList;
  m   : TMemoryStream;
  rv  : TRichViewEdit;
  rv   := TRichViewEdit.Create(Self);  [color=red] // The different create RichViewEdit [/color]
    rv.Parent := Self;
    rv.Style  := RvStyle1;
      m.Position := 0;
      m.Position := 0;
      rv.Format;
      FreeAndNil(List);
      FreeAndNil(m);
      m.Position := 0;
      m.Position := 0;
      rv.Format;
      FreeAndNil(List);
      FreeAndNil(m);
    // New RTFString
      m.Position := 0;
      m.Position := 0;
      FreeAndNil(List);
      FreeAndNil(m);
    FreeAndNil(rv);
LuckySpacy
Solution
I've got it!
TRvReporthelper is my friend.
Here is my solution:
function TfrmTest.MergeRTF(aRTFString1, aRTFString2: string): string;
  List: TStringList;
  m   : TMemoryStream;
  rh  : TRvReportHelper;
  rv  : TReportRichView;
  Style: TRvStyle;
  rh    := TRvReportHelper.Create(Self);
  Style := TRvStyle.Create(nil);
    rh.RichView.RTFReadProperties.TextStyleMode := rvrsAddIfNeeded;
    rh.RichView.RTFReadProperties.ParaStyleMode := rvrsAddIfNeeded;
    rh.RichView.RVFOptions := rh.RichView.RVFOptions + [rvfoSaveTextStyles];
    rh.RichView.RVFOptions := rh.RichView.RVFOptions + [rvfoSaveParaStyles];
    rv       := rh.RichView;
    rv.Style := Style;
    // Load RTFString1
    m.Position := 0;
    m.Position := 0;
    // Load RTFString2
    m.Clear;
    m.Position := 0;
    m.Position := 0;
    // New RTFString
    m.Position := 0;
    m.Position := 0;
    FreeAndNil(List);
    FreeAndNil(m);
    FreeAndNil(Style);
    FreeAndNil(rh);
TRichView controls created at runtime have different initial values of properties than controls placed on a form at designtime.
(we cannot change initial runtime values of properties because of compatibility reasons).
In the last code fragments, you change these properties:
This change allows loading RVF and RTF files without losing format.
Actually, you can do similar assignment to rv in your initial non-working code.
