Displaying HTML with ReportBuilder
Faber
Post by Faber »
I am trying to use the TRichView wrapper for RB to display HTML from a database field and I am not having much luck.
Is it possible to display HTML using TRichView and the RB wrapper?
HTML support is possible with use of TrvHtmlImporter component.
This component does not support CSS, but it can load a basic HTML.
To activate support, open ppRichView.pas and remove the dot from the line
{.$DEFINE RV_USE_HTML}
