[Example] How to scroll to selection
The function below scrolls to make selection visible.
It works both for TRichView and TRichViewEdit.
This function is especially useful in TRichView, because TRichView does not scroll after making selection (except for selecting with SearchText).
uses CRVFData, CRVData, Math;
procedure ShowSelection(rv: TCustomRichView);
var RVData: TCustomRVFormattedData;
    StartItemNo, StartOffs, EndItemNo, EndOffs: Integer;
    i, StartDItemNo, StartDOffs, EndDItemNo, EndDOffs: Integer;
    R: TRect;
  // finding subdocument containing selection (a main document or a cell)
  RVData := RV.RVData;
  while RVData.GetChosenRVData<>nil do
    RVData := TCustomRVFormattedData(RVData.GetChosenRVData);
  // getting selection
  RVData.GetSelectionBoundsEx(StartItemNo, StartOffs, EndItemNo, EndOffs, True);
  if (StartItemNo<0) or (EndItemNo<0) then
  // converting selection position from item indices to drawing item indices
  RVData.Item2DrawItem(StartItemNo, StartOffs, StartDItemNo, StartDOffs);
  RVData.Item2DrawItem(EndItemNo, EndOffs, EndDItemNo, EndDOffs);
  // (roughly) calculating selection coordinates in local coordinates of RVData
  with RVData.DrawItems[StartDItemNo] do
    R := Bounds(Left, Top, Width, Height);
  for i := StartDItemNo+1 to EndDItemNo do
    with RVData.DrawItems[i] do begin
      R.Left := Min(R.Left, Left);
      R.Top := Min(R.Top, Top);
      R.Right := Max(R.Right, Left+Width);
      R.Bottom := Max(R.Bottom, Top+Height);
  // scrolling to the selection
  RVData.ShowRectangle(R.Left, R.Top, R.Right-R.Left, R.Bottom-R.Top);
