Garbled text after using TRVHtmlImporter for Japanese html
mobipro
Post by mobipro »
Hi there,
I'm using TRVHtmlImporter to import html email from storage, this works well for single bype charsets, but when I try it with some Japanese email it results in garbaled text.
Below is a snippet of my code.
      if docType='HTML' then begin
        Editor.Clear;
        if XActiveLang = 7 then begin // Language = Japanese
          Importer.ClearDocument := False;
          Importer.DefaultFontName := 'MS PGothic';
          Importer.DefaultCFontName := 'MS PGothic';
          Importer.RichView.Style.DefCodePage := 932;
          Editor.RTFReadProperties.UnicodeMode := rvruOnlyUnicode;
          Editor.ClearUndo;
          ConvertRVToUnicode(Editor.RVData);
          for x := 0 to Importer.RichView.Style.TextStyles.Count -1 do begin
            Importer.RichView.Style.TextStyles[x].Unicode := True;
            Importer.RichView.Style.TextStyles[x].FontName := 'MS PGothic';
            Importer.RichView.Style.TextStyles[x].Charset := SHIFTJIS_CHARSET;
          Importer.LoadHtml(strList1.Text);
        end else
        Editor.Format;
      end else if docType='RTF'  then begin
Please tell me what I am doing wrong.
Thanks in advance.
Please send me an example of Japanese HTML file causing problems.
(I need to know how DBCS characters are encoded in this HTML)
mobipro
Sample html
Post by mobipro »
Hi there,
The html can vary as they are coming from email, in the case below it was a plan text email with html wrapped around it and save to disk, sorry I should have mentioned that.
Thanks in advance
Copied from explore:
I send e-mail of Japanese to you.
The contents, such as subject, sender name and body, are sent by attached file.
The subject and sender name will cause garbled characters.
I am looking forward to receiving your mail very soon.
Best Regards
----------Japanese Contents----------
„ª￾k￾†ŠO‚o‚q”Å￾l„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª
￾¡￾¡￾@￾@￾@￾@￾@￾@￾@ƒrƒWƒlƒX‘I￾‘￾•ƒTƒ}ƒŠ￾[
„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª ￾ƒ“ÇŽÒ￾” 48,642•”￾„„ª„ª
￾†ŠO‚o‚q”Å‚Í￾A“ÇŽÒ‚ÌŠF—l‚É‚¨–𗧂¿‚ÆŽv‚í‚ê‚é￾î•ñ‚ð￾A’Ê￾í‚Ì’è
Šú”Å‚Æ‚Í•Ê‚É•s’èŠú‚Å‚¨“Í‚¯‚µ‚Ä‚¢‚é‚à‚Ì‚Å‚·￾B
„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª
￾@„ª„­„ª„­„ª„­„ª„­„ª„­„ª„­„ª„­„ª„­„ª„­„ª„­„ª„­
￾@“]„«￾E„«‚Í„«￾î„«•ñ„«Žû„«￾W„«‚ª„«Œˆ„«‚ß„«Žè„«￾¡￾¡￾¡￾¡￾¡￾¡￾¡￾¡￾¡￾¡￾¡￾¡
￾@„ª„®„ª„®„ª„®„ª„®„ª„®„ª„®„ª„®„ª„®„ª„®„ª„®„ª„®
￾¡￾@￾Ÿ“]￾EƒTƒCƒg￾uƒŠƒNƒiƒr‚m‚d‚w‚s￾v￾Ÿ“]￾E￾î•ñŽ￾￾uƒr￾[ƒCƒ“ƒOŠÖ“Œ”Å￾v
￾¡￾@￾@￾@￾@￾@‚ª˜A“®Šé‰æ‚µ‚½￾AƒIƒXƒXƒ￾‚Ì‹￾￾l￾î•ñ‚ð‚¨‘—‚肵‚Ü‚·￾B
￾¡￾@￾@￾@￾@￾@￾š‚P‚P￾^‚R‚O￾i￾…￾j￾`‚P‚Q￾^‚U￾i‰Î￾j‚Ü‚Å‚ÌŠúŠÔŒÀ’è￾š
￾¡￾@„¬„ª„ª„ª„ª„ª„ª„ª„ª„ª„­„¬„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„­
￾¡￾@„«￾¡‚·‚®“]￾E‚µ‚½‚¢￾l„«„«￾«—ˆ“]￾E‚ð￾l‚¦‚Ä‚¢‚é￾l„«‚Ç‚¿‚ç‚à•KŒ©￾I
￾¡￾@„¯„ª„ª„ª„ª„ª„ª„ª„ª„ª„®„¯„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„®
￾¡„ª„ª„ª„ª￾«￾@￾âƒIƒXƒXƒ￾‚Ì‹￾￾l￾î•ñ‚Í‚±‚¿‚ç￾á￾@￾«„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª
￾¡￾@￾@￾@￾@￾¥–¢ŒoŒ±‚©‚ç￾uƒGƒ“ƒWƒjƒA￾v‚É‚È‚ê‚éŠé‹Æ￾¥
￾¡￾@￾@￾@￾@http://www.recruit.co.jp/BING/BP/PRE0550/FURI/U1.html
￾¡￾@￾@￾@￾@￾¥‹ÆŠE•ÏŠvŠé‹Æ‚ÌŽŸ￾¢‘ナ￾[ƒ_￾[•å￾W￾¥
￾¡￾@￾@￾@￾@http://www.recruit.co.jp/BING/BP/PRE0550/FURI/U2.html
￾@￾¡￾ „ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª„ª
￾@￾ ￾¡￾@–¢ŒoŒ±‚©‚ç￾uƒGƒ“ƒWƒjƒA￾v‚É‚È‚ê‚éŠé‹Æ
￾@￾`￾u‹Z￾p￾v‚ð￾g‚ɂ‚¯‚é‚Ì‚Í￾A￾¡‚©‚ç‚Å‚à’x‚­‚È‚¢￾I￾`
<html><body><br><br>I send e-mail of Japanese to you.<br>The contents, such as subject, sender name and body, are sent by attached file.<br>The subject and sender name will cause garbled characters.<br><br>I am looking forward to receiving your mail very soon.<br><br>Best Regards<br><br><br><br>----------Japanese Contents----------<br><br>$B(,!L9f30#P#RHG!M(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(B<br>$B"#"#"#(B<br>$B"#"#!!!!!!!!!!!!!!%S%8%M%9A*=q!u%5%^%j!<(B<br>$B"#(B<br>$B(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(B $B!cFI<T?t(B 48,642$BIt!d(,(,(B<br>$B9f30#P#RHG$O!"FI<T$N3'MM$K$*LrN)$A$H;W$o$l$k>pJs$r!"DL>o$NDj(B<br>$B4|HG$H$OJL$KITDj4|$G$*FO$1$7$F$$$k$b$N$G$9!#(B<br>$B(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(B<br><br><br>$B!!(,(/(,(/(,(/(,(/(,(/(,(/(,(/(,(/(,(/(,(/(,(/(B<br>$B!!E>(-?&(-$O(->p(-Js(-<}(-=8(-$,(-7h(-$a(-<j(-"#"#"#"#"#"#"#"#"#"#"#"#(B<br>$B!!(,(0(,(0(,(0(,(0(,(0(,(0(,(0(,(0(,(0(,(0(,(0(B<br>$B"#!!"!E>?&%5%$%H!V%j%/%J%S#N#E#X#T!W"!E>?&>pJs;o!V%S!<%$%s%04XElHG!W(B<br>$B"#!!!!!!!!!!$,O"F04k2h$7$?!"%*%9%9%a$N5a?M>pJs$r$*Aw$j$7$^$9!#(B<br>$B"#!!!!!!!!!!!z#1#1!?#3#0!J?e!K!A#1#2!?#6!J2P!K$^$G$N4|4V8BDj!z(B<br>$B"#!!(.(,(,(,(,(,(,(,(,(,(/(.(,(,(,(,(,(,(,(,(,(,(,(/(B<br>$B"#!!(-:#$9$0E>?&$7$?$$?M(-(->-MhE>?&$r9M$($F$$$k?M(-$I$A$i$bI,8+!*(B<br>$B"#!!(1(,(,(,(,(,(,(,(,(,(0(1(,(,(,(,(,(,(,(,(,(,(,(0(B<br>$B"#(,(,(,(,"-!!"d%*%9%9%a$N5a?M>pJs$O$3$A$i"c!!"-(,(,(,(,(,(,(,(,(,(,(,(B<br>$B"#!!!!!!!!"'L$7P83$+$i!V%(%s%8%K%"!W$K$J$l$k4k6H"'(B<br>$B"#!!!!!!!!(Bhttp://www.recruit.co.jp/BING/BP/PRE0550/FURI/U1.html<br>$B"#!!!!!!!!"'6H3&JQ3W4k6H$N<!@$Be%j!<%@!<Jg=8"'(B<br>$B"#!!!!!!!!(Bhttp://www.recruit.co.jp/BING/BP/PRE0550/FURI/U2.html<br>$B"#(B<br>$B"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#"#(B<br><br><br>$B!!"#""(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(B<br>$B!!"""#!!L$7P83$+$i!V%(%s%8%K%"!W$K$J$l$k4k6H(B<br>$B!!"#""(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(,(B<br><br><br>$B!!!A!V5;=Q!W$r?H$K$D$1$k$N$O!":#$+$i$G$bCY$/$J$$!*!A(B <br><br>
</body></html>
Sorry, I'm afraid this HTML was damaged when pasted in this forum.
Please send it to me as an attachment to [email protected]
