Newbie!! Please help
RogerGrib
Post by RogerGrib »
Hello everyone.
I'm trying to implement a ScaleRichViewEdit into my application, but I'm having a lot of trouble trying to figure out how to perform some basic tasks, like:
- how to load/save RTF files using ScaleRichViewEdit? (i mean, withou using the "file/save as" dialog)
- how to insert RTF code programmatically?
I looked for answers in the help file and here in the forum, but I could find no guide or tutorial on those subjects.
Any help would be very appretiated.
Loading RTF (without Clear, it would add to the end of the editor):
SRichViewEdit1.Clear
SRichViewEdit1.RichViewEdit.LoadRTF(FileName);
SRichViewEdit1.Format;
Inserting RTF code - what do you mean? Inserting RTF data? If you save RTF content to TMemoryStream, you can insert it in the caret position (as undoable operation):
Stream.Position := 0;
SRichViewEdit1.ActiveEditor.InsertRTFFromStreamEd(Stream);
TSRichViewEdit contains several invisible internal editors (RichViewEdit, RVHeader, RVFooter, RVNote) of TRichViewEdit type. TRichViewEdit is described in TRichView help, so you need to read both TRichView and ScaleRichView help
RogerGrib
Post by RogerGrib »
Thank you very much!
