Does it's possible to read a .msg files extract from Outlook to a TRichView ?
If yes, how ? I'm searching but noting works
Thanks,
Robin
Read Outlook files .msg
Sorry, I do not know a solution.
Probably, you can try to convert msg to eml (using IConverterSession interface - it requires installed Outlook!), then import eml (there is a ready-to-use example of loading eml files using CleverComponents+TrvHtmlViewImporter; but probably other components like Indy or Synapse can be used instead of CleverComponents)
Probably one of those components could help:
http://www.scalabium.com/msg/msglib.htm
or
http://www.rapware.nl/index.php?page=mapi-introduction
or
