Resetting a protected style
aoven
Post by aoven »
How does one change a style of an item in code, if the style has a rvprStyleProtect listed in Protection options?
Aleksander
StyleProtect protects from ApplyTextStyle, but does not protect from ApplyStyleConversion (checking this protection option in OnStyleConversion is a good idea, but not necessary).
Or you can temporary remove this option from the style and restore it.
Or you can use nonediting operation: RV.GetItem(i).StyleNo := NewStyle, then call Format.
aoven
Post by aoven »
Ah, so this is the one I was looking for, then - thanks!
I saw it already, but was a bit sceptical about using it, since it was a field, not a property.
Aleksander
