Hello, the demo RichView14\Demos\Delphi\Assorted\International\RTL\RTL.exe do not show file hebrew.rtf right. The letters show from left to right instead of right to left.
Can you solve this problem?
Hebrew language
If you select "Right to left" order in the context menu of Notepad, you will see the same results.
TRichView relies on Windows to order characters inside an item, so you can see this result.
The only solution - applying LTR to the specified paragraph or text fragments.
As for the demo, see http://www.trichview.com/forums/viewtopic.php?t=5810
