Function at same as "Memo.Text" ?
RichEnjoyer
Post by RichEnjoyer »
Hallo,
how become all chars in one string?
best wishes, Frank
See the functions in RVGetText.pas.
Or, if you need one-to-one correspondence between the document and the resulting string, functions from RVLinear.pas
Yernar Shambayev
Re: Function at same as "Memo.Text" ?
Post by Yernar Shambayev »
RichEnjoyer wrote:Hallo,
best wishes, Frank
function AllText(MyRV: TCustomRichView): string;
MyRV.SelectAll;
Result := Trim(MyRV.GetSelText);
Yernar, this procedure actually returns all the text (not necessary to Trim it), but :
1) it modifies RichView state (selects all document)
2) it requires document to be formatted (this is a disadvantage if you want load documents from files/database and quickly extract text from them)
