AddTextNL with Style Template
RedOne
Post by RedOne »
Hello
I like the new feature of the style templates in RichView 14.
But I have some understanding problems how the style templates and the textstyles are connected.
As an example, how can I add a text and set a proper style template?
Have I to use the StyleTemplateId-property?
One of many attempts:
function FindTextStyleByName( AName: string ): TFontInfo;
  i: Integer;
  for i:= 0 to rvEdit.Style.TextStyles.Count - 1 do begin
    if SameText( rvEdit.Style.TextStyles.Items[ i ].StyleName, AName ) then begin
      Result:= rvEdit.Style.TextStyles.Items[ i ];
procedure AddText;
  rvEdit.Clear;
  rvEdit.AddTextNL( 'Text without style', -1, -1, -1 );
  FindTextStyleByName( 'heading 1' ).StyleTemplateId:= rvEdit.Style.StyleTemplates.FindItemByName( 'heading 1' ).Id;
  rvEdit.AddTextNL( 'Text with style', FindTextStyleByName( 'heading 1' ).Index, -1, -1 );
// or with .ID?
  rvEdit.AddTextNL( 'Text with style', FindTextStyleByName( 'heading 1' ).ID, -1, -1 );
// Change a text style. This works fine
procedure TForm31.ButtonChangeStyleClick(Sender: TObject);
  index: Integer;
  frm: TfrmRVStyles;
  tmpstyle: TRVStyle;
  tmpstyle := TRVStyle.Create(Self);
  tmpstyle.StyleTemplates.AssignStyleTemplates( rvEdit.Style.StyleTemplates, true);
  with tmpstyle.StyleTemplates.FindItemByName( 'heading 1' ) do
   TextStyle.Color := clRed;
   ValidTextProperties := ValidTextProperties + [rvfiColor];
  rvEdit.ChangeStyleTemplates(tmpstyle.StyleTemplates);
  rvEdit.RVData.PaintBuffered;
  tmpstyle.free;
RedOne
1) Your AddText procedure really links a text style with a style template.
(Index must be used, TFontInfo does not have Id property)
However, this procedure does not assign properties of StyleTemplate to the text style. If you want to do it, instead of
call
FindTextStyleByName( 'heading 1' ).ModifiedProperties := [];
rvEdit.Style.StyleTemplates.FindItemByName( 'heading 1' ).ApplyToTextStyle(FindTextStyleByName( 'heading 1' ), nil);
2) Normally, the style templates "Normal", "heading 1", "heading 2", etc. are applied not to text, but to paragraphs (and affect all text inside paragraphs). An example of creating a new document with paragraph linked to "Normal" style template is here: http://www.trichview.com/help/idh_trvst ... style.html
3) The demo showing how to work with StyleTemplates without RichViewActions can be found in TRichView demos, in Demos\*\Editors\StyleTemplates\
