Mouse freezes with tables in some cases
sysmeht
Post by sysmeht »
Hi, I found that sometimes the mouse freezes when entering text into a table. The problem is intermittent, but I found away to reproduce it in RichView Action demo application (TRichView 14.5):
- create a new document
- add a 2x2 table
- click on the top-left cell
- press 'a' on keyboard and keep pressing, letters are written into top-left cell
- click into top-right cell, still pressing 'a'
- click into top-left cell, still pressing 'a'
- release 'a'
This stage the editor does not take the mouse clicks anymore, but the application is not frozen. This sometimes happens even with normal typing into cells.
Please check if you can reproduce the issue.
Thanks in advance!
I confirm the problem.
This bug was added in version 14.5.0
A quick fix:
Open RVERVData.pas, change
LastDIMovedAbove := -1;
to
  if CaptureMouseItem=nil then
sysmeht
Post by sysmeht »
Thanks for the quick fix, I can confirm that it works!
Best wishes!
