Setting Initial Font
w2m
Post by w2m »
I try to set the initial font for load pascal (*.pas} file as text but after loading font is not correct. How to load .pas file with 'Courier New' Font size = 10?
// set the initial font
      iFontInfo := TFontInfo.Create(nil);
        iFontInfo.FontName := 'Courier New';
        iFontInfo.Size := 10;
        iStyleNo := RichViewEdit.Style.TextStyles.FindSuchStyleEX(0, iFontInfo,
          RVAllFontInfoProperties);
        if iStyleNo < 0 then
          RichViewEdit.Style.TextStyles.Add;
          iStyleNo := RichViewEdit.Style.TextStyles.Count - 1;
          RichViewEdit.Style.TextStyles[iStyleNo].Assign(iFontInfo);
          RichViewEdit.Style.TextStyles[iStyleNo].Standard := False;
        iFontInfo.Free;
w2m
Post by w2m »
This should have been posted in the private forum because am a registered user. I do not know why it appeared here instead?
This code must work, if you pass iStyleNo variable as StyleNo parameter to RichViewEdit.LoadText.
This is a shorter code producing the same result (requires TRichView 14.x):
        iStyleNo := RichViewEdit.Style.FindTextStyle(iFontInfo);
        iFontInfo.Free;
PS: I can move this topic to the private section, but it does not contain anything specific to the newest full version, so it may be discussed here.
