Calculate table cell height.
I have upgraded TRichView to version 14 from 1.9.
A table generated using ver. 1.9 fills all page, but table generated using ver. 14.0 is sorter, does not fill all page, but contains this same contents. The table is only shorter. Due to this there are a margin on bottom of page.
I calculate cell height like this
Height:= Pixel_DPI+ //top frame of cell
TabCellPadding*Pixel_DPI+ //top padding
HeightOfFont+ //
TabCellPadding*Pixel_DPI+ //bottom padding
Pixel_DPI; //bottom frame
TabCellPadding := 2;
Pixel_DPI :=6.25 (calculated)
What does change ?
Regards
Michal
HeightOfFont+ //
What does change ?
Regards
Michal
A calculation of widths of table columns was changes several times, so, in some non-trivial cases, table width may be different for the same table.
Table width may affect table height because of line wrapping inside cells.
Otherwise, the only change I can remember is implementation of different cellpaddings: a horizontal and a vertical cellpadding (CellHPadding and CellVPadding).
It may be important if you import a table from MS Word-generated RTF, because by default MS Word's tables have different vertical and horizontal cellpaddings.
But if you generate your table yourself using table.CellPadding property, it must not affect the result.
I need a sample project to reproduce the problem.
Thanks for your replay.
When I change
HeightOfFont+ //
Pixel_DPI *0.70 ; //bottom frame
the table height is better calculated. Usually a table has one row more and the bottom margin is smaller.
In my tables there are no wrapped lines. After upgrade to current version of TRichView tables are shorter like before. It seams to cell height is a bit smaller then before.
I make mixed prints. There are text, tables some times pictures on them. What is proper way to calculate size of elements before insert them ?
For example I insert a few lines of text with different styles. Then I want to insert a table, but before this I have to know how many space are available on the page. Next during build the table I have to know how many space are available inside a table. After this I insert this table on page and create new empty page for next part of a print.
For now I calculate all myself.
There are in TRichView any functions to calculate it all ?
Regards
Michal
When I change
HeightOfFont+ //
Regards
Michal
To reproduce this behaviour you can build a simple table:
I can't separate the code, but I'm sending you the main procedures
Michal
procedure TFPD.InicjujTabele(Styl:byte);
n,m:byte;
IncWiersz(0,0); //zapamietuje poprzedni tekst
Inicjuj_WspT;
NrWiersza:=NrWiersza+2*Pixel_DPI; //obramowanie tabeli
fillChar(Tab,sizeOf(Tab),0);
for n:=0 to TAB_MAX_Wierszy-1 do begin
for m:=0 to TAB_MAX_Kolumn-1 do begin
Tab[n,m].RGora :=false; //true;
Tab[n,m].RDol :=true;
Tab[n,m].RLewa :=false; //true;
Tab[n,m].RPrawa :=true;
Tab[n,m].PolaczonaX:=m; //sama ze soba, co znaczy ze nie jest polaczona
Tab[n,m].PolaczonaY:=n; //sama ze soba, co znaczy ze nie jest polaczona
Tab[n,m].Kolor :=clNone;
Tab[n,m].Styl :=Styl;
Tab[n,m].Pad :=D_PadL;
Tab[n,m].NrObrazka :=0;
if n=TAB_MAX_Wierszy-1 then Tab[n,m].RDol:=false;
if m=TAB_MAX_Kolumn-1 then Tab[n,m].RPrawa:=false;
CzyObrys :=true;
NrWierszaTab:=0;
procedure TFPD.Tabela(IleWierszy,IleKolumn:word;Szerokosc,PAD:SmallInt; PlikTla:string);
table : TRVTableItemInfo;
ramki : TRVBooleanRect;
m,n,o : byte;
ByloPolaczenieX:boolean;
IlePolaczycX:byte;
ByloPolaczenieY:boolean;
IlePolaczycY:byte;
AktualnyStylTmp:byte;
bmp,bmpTlo:TBitmap;
ss:string;
xxx:integer;
Szer,Wys:longint;
CzyBMP:boolean;
JPG:TJPEGImage;
MS:TStream;
AktualnyStylTmp:=AktualnyStyl;
if IleWierszy>0 then
for n:=0 to IleWierszy-1 do begin
if IleKolumn>0 then
for m:=0 to IleKolumn-1 do begin
if n=IleWierszy-1 then Tab[n,m].RDol:=false;
if m=IleKolumn-1 then Tab[n,m].RPrawa:=false;
if Tab[n,0].Blok_Start then Tab[n,m].RGora:=true;
if Tab[n,0].Blok_End then Tab[n,m].RDol:=true;
// Stale definiujace wyglad tabeli - raczej nie zmienic !!!
table := TRVTableItemInfo.CreateEx(IleWierszy,IleKolumn, RVE.RVData);
table.ParaNo := PAD;
table.Color := clWhite; //clNone; //clWhite;
table.BorderLightColor := clNone; //=trnsparent //clWhite;
if CzyObrys
then table.BorderColor := clBlack
else table.BorderColor := clNone;
table.CellBorderColor := clGray;
table.CellBorderLightColor := clNone; //clWhite;
table.BorderStyle := rvtbColor; // rvtbRaisedColor;
table.CellBorderStyle := rvtbColor; //rvtbLoweredColor;
// TRVTableBorderStyle = (rvtbRaised, rvtbLowered, rvtbColor, rvtbRaisedColor, rvtbLoweredColor);
table.VRuleWidth:=0;
table.VRuleColor:=clYellow;
table.VOutermostRule:=False;
table.HRuleWidth:=0;
table.HRuleColor:=clYellow;
table.HOutermostRule:=False;
table.BorderWidth := 1; //0 - oznacza ze bez ramki
table.BorderVSpacing := 0;
table.BorderHSpacing := 0;
table.CellBorderWidth := 1; //0 - oznacza ze nie ma ramek komorek;
table.CellPadding := 2; //2 - oznacza szerokosc ramki wkolo tekstu wewnatrz komorki ;
table.CellVSpacing := 0;
table.CellHSpacing := 0;
if Pokaz_Siatke_Tabel
then table.Options:=table.Options-[rvtoHideGridLines]
else table.Options:=table.Options+[rvtoHideGridLines];
//Ustawienie szerokosci kolumn tabeli i polaczen komorek w wierszu oraz koloru komorek
if IleKolumn>0 then
table.Cells[n,m].BestWidth := Tab[0,m].Szerokosc;
table.Cells[n,m].BorderLightColor := Tab[n,m].Kolor;
table.Cells[n,m].Color := Tab[n,m].Kolor;
{ TODO : Komponent nie obsluguje prawidlowo tej wlasciwosci troche lepiej jest dla rvtbRaised}
//2007.07
case Tab[n,m].Pad_V of
D_PAD_G: table.Cells[n,m].VAlign := rvcTop;
D_PAD_S: table.Cells[n,m].VAlign := rvcMiddle;
D_PAD_D: table.Cells[n,m].VAlign := rvcBottom;
else table.Cells[n,m].VAlign := rvcVDefault;
m:=0;
ByloPolaczenieX:=false;
ByloPolaczenieY:=false;
IlePolaczycX:=0;
IlePolaczycY:=0;
while m<=IleKolumn-1 do begin
// dla X
if (Tab[n,m].PolaczonaX<>m) then begin
inc(IlePolaczycX);
ByloPolaczenieX:=true;
end else begin
if ByloPolaczenieX then begin
inc(IlePolaczycX);
table.MergeCells(n,m-IlePolaczycX,IlePolaczycX,1,FALSE);
IlePolaczycX:=0;
//Dla Y
if (Tab[n,m].PolaczonaY<>n) then begin
table.MergeCells(Tab[n,m].PolaczonaY,m,1,1+n-Tab[n,m].PolaczonaY,FALSE);
inc(m);
inc(IlePolaczycX);
// table.MergeCells(0,0,6,1,FALSE);
// table.MergeCells(0,6,5,1,FALSE);
// table.MergeCells(3,1,3,1,FALSE);
// table.MergeCells(3,4,2,1,FALSE);
// table.Select(3,1,1,1);
// table.SplitSelectedCellsVertically(3);
o:=0;
if Tab[0,0].NrObrazka<>0 then begin
o:=1;
InicjujStyle;
if IleKolumn>0 then
for m:=o to IleKolumn-1 do begin
with Table.Cells[n,m] do begin
if (Tab[n,m].PolaczonaX=m) and
(Tab[n,m].PolaczonaY=n)
then begin
Clear;
ramki:=VisibleBorders;
ramki.SetValues(Tab[n,m].RLewa, Tab[n,m].RGora,
Tab[n,m].RPrawa, Tab[n,m].RDol );
VisibleBorders:=ramki;
//AddNL(Tab[n,m].Tresc,Tab[n,m].Styl,Tab[n,m].Pad);
if Tab[n,m].SzerTXT>0 then begin {2004.08.17}
Szer:=0;
Wys :=0;
ss:=trim(Tab[n,m].Tresc);
WymiarTXT(ss,Tab[n,m].Styl,Szer,Wys);
if Szer > Tab[n,m].SzerTXT then begin
repeat
ss:=trim(ss);
if ss<>'' then delete(ss,length(ss),1);
ss:=trim(ss);
WymiarTXT(ss+'...',Tab[n,m].Styl,Szer,Wys);
until Szer <= Tab[n,m].SzerTXT;
ss:=ss+'...';
AddNL(ss ,Tab[n,m].Styl,Tab[n,m].Pad);
end else begin
AktualnyStyl:=Tab[n,m].Styl;
AktualizujWystepowanieStylow;
except
on E:Exception do begin end;
// IncWiersz(1,0);
table.MergeCells(0,0,1,IleWierszy,FALSE);
bmp:=TBitmap.Create;
bmp.Assign(TabBmp[Tab[0,0].NrObrazka].Obrazek);
table.cells[0,0].Clear;
table.cells[0,0].AddPictureEx('',bmp,D_PadC,rvvaMiddle);
table.BorderWidth := 0;
table.CellBorderWidth := 0;
table.CellBorderColor :=clNone;
//bmp.Free; - powoduje blad
// table.InsertRows(3,10,1,false);
// with table.Cells[2,0] do begin
// Clear;
// AddNL('Another example.',0,0);
// SetItemExtraIntProperty(ItemCount-1, rvepResizable, 1);
// AddNL('Width of table = 90% of document width. Widths of cells = 16%',0,0);
// end;
// table.BackgroundImageFileName:='d:\BDS2006\Apl\FVat\#\Polecenie.bmp';
if FileExists(PlikTla) then begin
bmpTlo := TBitmap.Create;
CzyBMP:=(FileExt(UpStr(PlikTla))='BMP');
if CzyBMP then begin
bmpTlo.LoadFromFile(PlikTla);
except
msgBox({self,}'Problem z za³adowaniem pliku:'+#13+#13+PlikTla, mfOK);
end else begin
JPG := TJPEGImage.Create;
JPG.LoadFromFile(PlikTla);
bmpTlo.Assign(JPG);
// MS:=TMemoryStream.Create;
// JPG.SaveToStream(MS);
// bmpTlo.LoadFromStream(MS);
// MS.Free;
JPG.Free;
except
table.BackgroundImage := bmpTlo;
table.BackgroundStyle := rvbsStretched; //rvbsTiled;//rvbsCentered;//rvbsStretched;
bmpTlo.Free;
table.BestWidth := Szerokosc;
RVE.AddItem('', table);
InicjujStyle;
procedure TworzTabele(Styl:byte);
Wsp:double;
x,y:byte;
Wsp:=1.00;
case Styl of
Arial_3: Wsp:=WspT_Arial3;
Arial_3b: Wsp:=WspT_Arial3b;
Arial_3i: Wsp:=WspT_Arial3i;
Arial_3bi: Wsp:=WspT_Arial3bi;
Arial_3u: Wsp:=WspT_Arial3u;
Arial_6: Wsp:=WspT_Arial6;
Arial_6b: Wsp:=WspT_Arial6b;
Arial_6i: Wsp:=WspT_Arial6i;
Arial_6bi: Wsp:=WspT_Arial6bi;
Arial_6u: Wsp:=WspT_Arial6u;
Arial_7: Wsp:=WspT_Arial7;
Arial_7b: Wsp:=WspT_Arial7b;
Arial_7i: Wsp:=WspT_Arial7i;
Arial_7bi: Wsp:=WspT_Arial7bi;
Arial_7u: Wsp:=WspT_Arial7u;
Arial_8: Wsp:=WspT_Arial8;
Arial_8b: Wsp:=WspT_Arial8b;
Arial_8i: Wsp:=WspT_Arial8i;
Arial_8bi: Wsp:=WspT_Arial8bi;
Arial_8u: Wsp:=WspT_Arial8u;
Arial_9: Wsp:=WspT_Arial9;
Arial_9b: Wsp:=WspT_Arial9b;
Arial_9i: Wsp:=WspT_Arial9i;
Arial_9bi: Wsp:=WspT_Arial9bi;
Arial_9u: Wsp:=WspT_Arial9u;
Arial_10: Wsp:=WspT_Arial10;
Arial_10b: Wsp:=WspT_Arial10b;
Arial_10i: Wsp:=WspT_Arial10i;
Arial_10bi: Wsp:=WspT_Arial10bi;
Arial_10u: Wsp:=WspT_Arial10u;
Arial_12: Wsp:=WspT_Arial12;
Arial_12b: Wsp:=WspT_Arial12b;
Arial_12i: Wsp:=WspT_Arial12i;
Arial_12bi: Wsp:=WspT_Arial12bi;
Arial_12u: Wsp:=WspT_Arial12u;
Arial_14: Wsp:=WspT_Arial14;
Arial_14b: Wsp:=WspT_Arial14b;
Arial_14i: Wsp:=WspT_Arial14i;
Arial_14bi: Wsp:=WspT_Arial14bi;
Arial_14u: Wsp:=WspT_Arial14u;
Curier_7: Wsp:=WspT_Curier7;
Curier_7b: Wsp:=WspT_Curier7b;
Curier_7i: Wsp:=WspT_Curier7i;
Curier_7bi: Wsp:=WspT_Curier7bi;
Curier_7u: Wsp:=WspT_Curier7u;
Curier_10: Wsp:=WspT_Curier10;
Curier_10b: Wsp:=WspT_Curier10b;
Curier_10i: Wsp:=WspT_Curier10i;
Curier_10bi: Wsp:=WspT_Curier10bi;
Curier_10u: Wsp:=WspT_Curier10u;
NowaStrona(false);
InicjujTabele(Styl);
Zostalo:=0;
for x:=0 to 73 do begin
if CzyNowaStrona(Wsp,1,NrWierszaTab,Zostalo) and CzyPodzial
then begin
Tabela(NrWierszaTab,10,-100, D_PADL);
NowaStrona(False);
if NrWierszaTab=0 then begin
Tab[0,0].Szerokosc:=-5;
Tab[0,1].Szerokosc:=-15;
Tab[0,2].Szerokosc:=-12;
Tab[0,3].Szerokosc:=-12;
Tab[0,4].Szerokosc:=-10;
for y:=5 to 9 do begin
Tab[0,y].Szerokosc:=-5;
Tab[NrWierszaTab,0].Tresc:=intToStr(x+1);
Tab[NrWierszaTab,1].Tresc:=RVStyle1.TextStyles.Items[Styl].StyleName{+#182+#222};
Tab[NrWierszaTab,0].Pad :=D_PADR;
IncWiersz(1,NrWierszaTab);
Tab[NrWierszaTab,2].Tresc := realToStr(NrWiersza,2);
Tab[NrWierszaTab,3].Tresc := realToStr(Zostalo-Wsp,2);
Tab[NrWierszaTab,4].Tresc := realToStr(Wsp,2);
inc(NrWierszaTab);
if NrWierszaTab>0 then Tabela(NrWierszaTab,10,-100, D_PADL);
Michal
You may insert a simple table of about 60 rows and 4 columns. In first cell of each row you can write number of the row using Arial 9 font.
Probably 60 rows will fill a A4 page.
Then you can create the page using RVE 1.9 and 14. On RVE 14 table should have more rows then on 1.9, because height of each row is a bit shorter.
Michal
Michal
I made this test, compared version 14.3 and 1.9.0.4
As a result, the both versions show the same table height in Caption (1262).
I compared screenshots in a graphical editor. While column widths are different (because the old version made a filled column wider than empty columns), row heights are exactly the same.
var table : TRVTableItemInfo;
r: Integer;
RVStyle1.TextStyles.Clear;
with RVStyle1.TextStyles.Add do begin
FontName := 'Arial';
table := TRVTableItemInfo.CreateEx(60, 4, RichView1.RVData);
table.BorderColor := clBlack;
RichView1.AddItem('', table);
for r := 0 to table.Rows.Count-1 do begin
table.Cells[r, 0].Clear;
table.Cells[r, 0].AddFmt('%d', [r], 0, 0);
RichView1.AddNL(RVVersion, 0, 0);
RichView1.Format;
Caption := IntToStr(table.GetHeight(RVStyle1)); -- for 14.3
Caption := IntToStr(table.Height); -- for 1.9.0.4
