Custom Filter in RichViewActions Open and SaveAs
keith
Post by keith »
Hi. Is there a way to have RichViewActions put the Custom Filter first in the list of filters for the Open and SaveAs dialogs? Or have it select a custom filter as the default?
Keith
TrvActionOpen has LastFilterIndex as a public property. This property specifies the filter index (starting from 1) which will be used by default when the action will be executed next time.
You can set initial value of this property.
