Demo/Example Required
philipljackson
Post by philipljackson »
Hi
Due to problems with TxTextControl being installed in Delphi XE, I need to create a full word processor type application and get it up and running in the shortest possible time.
The actionTest example would form an excellent solution to my problem - is the source code available or can you point me in the direction of something similar?
Thanks in advance.
Philip L Jackson
Source code of the ActionTest demo (compiled version: http://www.trichview.com/resources/acti ... ontest.zip ) is included in RichViewActions.
There are two projects:
ActionTestUni.dproj - using TCoolBar
Ribbon\ActionTestRibbon.dproj - using TRibbon
If you want similar demos for ScaleRichView, they are included in ScaleRichView demos.
