Installation in Delphi XE2
PioPio
Post by PioPio »
I am trying to install the Trial under Delphi XE2. I succesfully installedRVPkgDXE2.dproj but if I try to install RVDBPkgDXE2.dproj Delphi says DBRV.dcu is not found.
I checked in the trial folder and I can't find any DBRV.pas or DBRV.dcu
How can I solve this ?
Many thanks
Pio Pio
rvpkg.zip, the folder 1-TRichView\Trial\XE2\ does contain DBRV.dcu
rvpkgcb.zip has it in the same folder as well.
