rvhtmlviewimporter & html entities
cjw
Post by cjw »
I'm using rvhtmlviewimporter to import html to richviewedit. However the imported html with entities such as   show up either as weird characters or '?'.
Imported html:
<html>
<head>
<title></title>
<link REL="stylesheet" TYPE="text/css" HREF="demo.css">
</head>
<body CLASS="indent">
<p CLASS="heading"><a NAME="a">Test</a></p>
<p>test &nbsp; import&html&nbsp;&nbsp;
<br>
&nbsp;</p>
</body>
</html>
Output in richviewedit:
How do I get them to show up properly?
Do you use rvhtmlviewimporter? If yes, does this document look correctly in THTMLViewer?
cjw
Post by cjw »
Yes using rvhtmlviewimporter. Documents shows up fine in THTMLViewer.
cjw
Post by cjw »
This is the code where I'm importing the html to a richviewedit.
ss := TStringStream.Create(html);
htmlViewer.LoadFromStream(ss);
rvHtmlViewImporter.ImportHtmlViewer(htmlViewer, rv);
NormalizeRichView(rv.RVData);
rv.Format;
Which version of Delphi? Version of HTMLViewer?
cjw
Post by cjw »
Delphi 6 with HTMLViewer 11.3.
cjw
Post by cjw »
Problem solved by adding following code before loading html
rv.Clear;
rv.Style.TextStyles[0].Unicode := true;
Thanks for the time.
I cannot reproduce this problem even if the first text style is not Unicode.
Can you send me a simple project reproducing this problem?
cjw
Post by cjw »
Sent a project producing the problem to svt at trichview dot com.
