Impossible to try ScaleRichView
jhonalone
Post by jhonalone »
I am a registered user of TRichView, updated at 14.0.3 version.
I download trial version.
I'm trying to install trial version of TSRichView, but is impossible because installing SRVPkgD7.dpk Delphi shows this compiler error: "Unit SRVControl was compiled with a different version of RichView.TCustomRichView"
How can I try ScaleRichView?
Thanks.
Did you try ScaleRichView from this link:
http://www.trichview.com/rvfiles/scaler ... chview.zip ?
This is a trial version compatible with the registered version of TRichView.
jhonalone
Post by jhonalone »
OK. Solved.
Thank you very much.
