[Example] Converting table to text
This example "removes" the table at the caret position without removing its content:
procedure ConvertTableToText(RichViewEdit: TCustomRichViewEdit);
var table: TRVTableItemInfo;
    rv: TRichView;
    rve: TCustomRichViewEdit;
    Stream: TMemoryStream;
    ItemNo,r,c: Integer;
  if not RichViewEdit.GetCurrentItemEx(TRVTableItemInfo, rve,
TCustomRVItemInfo(table)) then
  rv := TRichView.Create(nil);
    rv.Visible := False;
    rv.Parent := RichViewEdit.Parent;
    rv.Style := RichViewEdit.Style;
    rv.RVFTextStylesReadMode := rvf_sIgnore;
    rv.RVFParaStylesReadMode := rvf_sIgnore;
        if table.Cells[r,c]<>nil then begin
            table.Cells[r,c].GetRVData.SaveRVFToStream(Stream, False, clNone, nil, nil);
            Stream.Position := 0;
            rv.InsertRVFFromStream(Stream, rv.ItemCount)
            Stream.Free;
    ItemNo := table.GetMyItemNo;
      rv.SaveRVFToStream(Stream, False);
      rve.SetSelectionBounds(ItemNo, 0, ItemNo, 1);
      rve.InsertRVFFromStreamEd(Stream);
      Stream.Free;
    rv.Free;
The same for C++Builder:
void ConvertTableToText(TCustomRichViewEdit* RichViewEdit)
  TCustomRVItemInfo   *item;
  TCustomRichViewEdit *rve;
  if (! RichViewEdit->GetCurrentItemEx(__classid(TRVTableItemInfo), rve,
item))
    return;
  TRVTableItemInfo*table = (TRVTableItemInfo*)item;
  TRichView* rv = new TRichView((TComponent*)NULL);
  rv->Visible = false;
  rv->Parent  = RichViewEdit->Parent;
  rv->Style   = RichViewEdit->Style;
  rv->RVFTextStylesReadMode = rvf_sIgnore;
  rv->RVFParaStylesReadMode = rvf_sIgnore;
  for (int r=0; r<table->Rows->Count; r++)
    for (int c=0; c<table->Rows->Items[r]->Count; c++)
      if (table->Cells[r][c])
        TMemoryStream*Stream = new TMemoryStream;
        table->Cells[r][c]->GetRVData()->SaveRVFToStream(Stream, false,
          clNone, NULL, NULL);
        Stream->Position = 0;
        rv->InsertRVFFromStream(Stream, rv->ItemCount);
        delete Stream;
  int ItemNo = table->GetMyItemNo();
  rv->SaveRVFToStream(Stream, false);
  rve->SetSelectionBounds(ItemNo, 0, ItemNo, 1);
  rve->InsertRVFFromStreamEd(Stream);
  delete Stream;
  delete rv;
Last edited by Sergey Tkachenko on Sun Oct 02, 2011 7:53 pm, edited 2 times in total.
This version of ConvertTableToText inserts ';' instead of line breaks between table cells (line breaks are inserted between rows).
It has a new parameter: EqualDelimCount.
If it is True, the same number (table.ColCount-1) of semicolons will be inserted for each row.
If it is False, semicolons will not be used for horizontally merged cells.
For example, for this table:
EqualDelimCount=False:
1;2;3
4;5
;6
EqualDelimCount=True:
1;2;3
4;;5
;;6
uses RVNormalize; // from RichViewActions
procedure ConvertTableToText(RichViewEdit: TCustomRichViewEdit; EqualDelimCount: Boolean);
    rv: TRichView;
    ItemNo,r,c, mr, mc: Integer;
    NewLine: Boolean;
    for r := 0 to table.RowCount-1 do begin
      NewLine := True;
      for c := 0 to table.ColCount-1 do begin
        if (c<>0) then begin
          if EqualDelimCount then
            if NewLine then
              rv.AddNLATag(';',0, 0, '')
              rv.AddNLATag(';',0,-1, '')
          else begin
            table.Rows.GetMainCell(r, c, mr, mc);
            if mc=c then
              if NewLine then
              if NewLine then
                rv.AddNLATag('',0, 0, '');
          NewLine := False;
            if ((c=0) and (r<>0)) or NewLine or
               (table.Cells[r,c].GetRVData.GetItemStyle(0)=rvsListMarker) or
               table.Cells[r,c].GetRVData.GetItem(0).GetBoolValue(rvbpFullWidth) then
              rv.AppendRVFFromStream(Stream, -1);
            NewLine := False;
            Stream.Free;
    NormalizeRichView(rv.RVData);
      Stream.Free;
    rv.Free;
Ways to improve:
1) this code uses TextStyles[0] and ParaStyles[0] for AddNLATag. You can change it to text style from table cells.
2) to do something with semicolons and line breaks inside table cells (this code keeps them as they are)
Note: a slightly improved version of this code is included in RichViewActions. It is used in TrvActionTableToText.
Updates:
2011-Oct-2: for compatibility with TRichView 13.4
The examples above convert the current table (at the caret position) as an editing operation. The user can undo it.
The procedure ConvertAllTablesToText below converts all tables, without a possibility to undo. If Recursive=True, nested tables are converted as well.
procedure ConvertAllTablesToText(RVData: TCustomRVData;
  Recursive: Boolean); forward;
procedure ConvertOneTableToText(RVData: TCustomRVData; ItemNo: Integer;
    rv: TRichView;
    r,c: Integer;
    Color: TColor;
  table := RVData.GetItem(ItemNo) as TRVTableItemInfo;
  if Recursive then
          ConvertAllTablesToText(table.Cells[r,c].GetRVData, Recursive);
    rv.Style := RVData.GetRVStyle;
            Stream.Free;
    RVData.DeleteItems(ItemNo, 1);
      RVData.InsertRVFFromStream(Stream, ItemNo, Color, nil, nil, False, nil, nil);
      Stream.Free;
    rv.Free;
var i: Integer;
  for i := RVData.ItemCount-1 downto 0 do
    if RVData.GetItemStyle(i)=rvsTable then
      ConvertOneTableToText(RVData, i, Recursive);
How to use:
  ConvertAllTablesToText(RichViewEdit1.RVData, True);
  RichViewEdit1.Format;
  RichViewEdit1.ClearUndo;
Update:
2018-Apr-9: changed for compatibility with TRichView 17
Last edited by Sergey Tkachenko on Sun Oct 02, 2011 7:54 pm, edited 1 time in total.
