How to extend the standard updation of TrvAction
vit
Post by vit »
I’ve already wrote the similar question but I haven’t got the answer :( So now I repeat it in other words I hope you’ll help me.
I want to extend the updation of TrvAction. For example there is TrvActionTableInsertRowsBelow. It’s enabled when the cursor is at the table and document is not read-only and so on. I need to save this behavior and add some extra conditions. For example I want to action is only enabled if the table has 3 columns and 2 rows.
In order to achieve this I add TrvActionTableInsertRowsBelow to the action list and implement OnUpdate event:
procedure TForm1.aInsertRowsBellowUpdate(Sender: TObject);
  (Sender as TAction).Enabled := AreMyConditionsSatisfied;
But this approach is not correct because it doesn’t use the standard conditions checking of TrvActionTableInsertRowsBelow. If I understood right, at this point (Sender as TAction).Enabled doesn't contain the value which is calculated by TrvActionTableInsertRowsBelow, this is just value remained from previous checking.
Probably, the best solution is creating an action inherited from TrvActionInsertRowsBelow.
Also, you can process focus change and OnCaretMove event, and set Disabled=True property for the action if your condition is not satisfied.
