Picture alignment after RTF export in Word
mboth
Post by mboth »
Greetings Sergey,
long time no problem.... now this came up:
ScaleRichView 4.0.1
When I insert a picture into a document, then using rvactions set VAlign = rvvaRight, it displays correctly in ScaleRichView.
When I export as RTF and open it in Word 2003, the alignment information is lost. The picture shows as if it was aligned on baseline.
I was able to reproduce this in ActionTest (13.0.1, act3.0.1, srv4.0)
How can I export alignment information for pictures with rtf?
Unfortunately, picture alignment is not exported to RTF.
MS Word aligns pictures differently, there are no direct analog for pictures' VAlign.
mboth
Post by mboth »
Thanks for the answer... Bad news, though... Is there any workaround other then manually adjust alignment in Word?
Moritz
Sorry, no.
