Converting indentations to spaces when saving as .TXT?
PeterPanino
Post by PeterPanino »
Hi! I have a RichViewEdit where some paragraphs are indented. Now, when I export the document to plain text (.TXT), the paragraph indentations should automatically be converted to spaces. Is there an option to do this automatically or do I have to write an OnSaveItemToFile event-handler?
There is no automatic conversion of indentation to spaces.
You can either use OnSaveItemToFile, or create a copy of this document in a hidden TRichView, add spaces, and save.
PeterPanino
Is there any example on how to do this in the OnSaveItemToFile event-handler?
This code adds 3 spaces at the beginning of paragraphs having the first line indented.
procedure TForm3.RichViewEdit1SaveItemToFile(Sender: TCustomRichView;
  const Path: string; RVData: TCustomRVData; ItemNo: Integer;
  SaveFormat: TRVSaveFormat; Unicode: Boolean; var OutStr: TRVRawByteString;
  var DoDefault: Boolean);
  if SaveFormat<>rvsfText then
  if not RVData.IsParaStart(ItemNo) or
    (RVData.GetRVStyle.ParaStyles[RVData.GetItemPara(ItemNo)].FirstIndent<=0) then
 DoDefault := False;
 if Sender.Style.TextStyles[RVData.GetItemStyle(ItemNo)].Unicode then begin
   OutStr := ' '#0' '#0' '#0+OutStr;
   if not Unicode then
     OutStr := RVU_UnicodeToAnsi(CP_ACP, OutStr);
   end
 else begin
   OutStr := '   '+OutStr;
   if Unicode then
     OutStr := RVU_AnsiToUnicode(RVData.GetItemCodePage(ItemNo), OutStr);
Problems:
1) This code does not add spaces for paragraphs started from a non-text item.
2) Unlike the standard text saving procedure, this code does not make a special processing when saving text of SYMBOL_CHARSET's font, like "Symbol" or "Windgdings"
3) This code ignores CodePage parameter of SaveText. You can store this code page in a global variable, and use it instead of CP_ACP.
Actually, I think that creating a modified copy is a better approach.
