Rotating cell content
shapoval
Post by shapoval »
I've tried to use the new Cell.Rotation functionality and have got a problem. The cell content is rotated as expected, but the cell itself doesn't resize accordingly. So, if I have a cell, which contains a single line of text, after resizing it remains the same wide cell with low height and the rotated word is wrapped practically on each letter. Shall I adjust the cell height manually or something is going wrong in the code and I need to look for the problem?
Other related question - I use eDocEngine converter to convert the stuff to PDF. At the moment it doesn't seem that it can process rotated labels - the text doesn't fit the cells and is printed outside of the table (not rotated). Again, the question is whether it's supposed to work or not? I understand that it's not really a question to you, but you may know the answer.
1) Yes, if cell content is rotated, it does not affect calculation of cell size (the same for vertical text in MS Word). You need to resize this cell manually
2) Please address this question to Gnostice.
