convert Page Break and Section Break to Paragraph Break
Riley Meadows
Post by Riley Meadows »
Hi.
Is there any way to convert any Page Break and any Section Break to Paragraph Break? I mean by using code (programatically)...
Thank you.
Regards, Riley
TRichView does not support section breaks yet.
Page breaks are already in places of paragraph breaks (or in places of line breaks inside paragraph), so all you need is removing page breaks.
1) You can simply assign RVPrint.IgnorePageBreaks = True to ignore all explicit page breaks.
2) The code for removing all page breaks:
procedure RemovePageBreaks(RVData: TCustomRVData);
var i, r, c: Integer;
   table: TRVTableItemInfo;
  for i := 0 to RVData.ItemCount-1 do begin
    RVData.PageBreaksBeforeItems[i] := False;
    if RVData.GetItemStyle(i)=rvsTable then begin
      for r := 0 to table.RowCount-1 do begin
        table.Rows[r].PageBreakBefore := False;
          if table.Cells[r,c]<>nil then
            RemovePageBreaks(table.Cells[r,c].GetRVData));
Call:
  RemovePageBreaks(RichViewEdit1.RVData);
Riley Meadows
It works for page breaks, thank you.
Do you have a timetable for when you will also implement Section Breaks?
Regards, Riley
Not soon, sorry. There are other works with higher priority, so I am afraid in 2013 sections will not be implemented.
