Richview Actions - Menuitems has no effect
BernhardRoos
Post by BernhardRoos »
I'm using the example unit for editing Richviews. This unit is using Richview Actions for Menu items. In my main application it works fine.
But I'm using the same unit in a dll. If the user clicks on a menu item, it happens nothing.
Have I forgotten something to do in the dll project, so that the Richview Action component is activating?
Best wishes
Bernhard
See http://www.trichview.com/forums/viewtopic.php?t=4249
Note: distributing DLL or ActiveX containing TRichView requires a special permission from us (see license.txt).
Normally, if this DLL is used only by your applications, it's OK.
BernhardRoos
Thanks for your answer.
We are using the dll only for our application. We have a c# program for which we are needing a good Reportbuilder. So we are programming a dll which which uses the Reportbuilder and Richview Components.
Is this ok? Or is it not allowed to distribute the dll as part of our c# program?
Best wishes
Bernhard
If it is used only by your application, it's ok.
BernhardRoos
Yes, it is only used by our application.
Best wishes
Bernhard
