I'm using the method TSRichViewEdit.DrawPage to get my text printed.
I'm using that method beacause I need to print the background.
The problem is that all the bullets get printed too large and out of place.
The text and the background are just fine.
I really don't understand what migth be the problem.
Do you know the cause of this behavior?
Thanks in advance.
Juan.
Bullets print wrong with SRichViewEdit.DrawPage
Unfortunately, you cannot call DrawPage for Printer.Canvas.
This method needs to change Canvas.Font.PixelsPerInch temporarily, but TPrinterCanvas does not allow to do it.
A workaround:
1. Declare
2. In the beginning, after Printer.BeginDoc:
In the call of
3. In the calls of DrawPage, change Printer.Canvas to PageCanvas
4. In the end:
A workaround:
1. Declare
var PageCanvas: TCanvas;
PageCanvas := TCanvas.Create;
PageCanvas.Handle := Printer.Canvas.Handle;
4. In the end:
PageCanvas.Handle := 0;
PageCanvas.Free;
