we have problem to determine the y coord of controls which are inside a table cell, which are longer than the screen height of the Richview.
We are using
TRichView(c.Parent).GetItemCoords(TRichView(c.Parent).FindControlItemNo(c), x, y);
y has the correct value if the height of the table cell isn't higher than the height of the Richview component. Otherwise I get a wrong value.
Any ideas?
What I want to do is, that the Richview scroll to the control if the control get the focus. Can I do this with another method like for example Richview.ControlInView(c) or something else?
Best wishes
Bernhard
Coordinate of Controls whicht are inside table cells
GetItemCoords returns coordinates related the cell inplace editor.
They can be recalculated, but I suggest this method:
where
var RVData:TCustomRVData;
ItemNo: Integer;
FindControlLocation(RichViewEdit1.RVData, c, RVData, ItemNo);
RichViewEdit1.GetItemCoordsEx(TCustomRVFormattedData(RVData), ItemNo, 0, True, ControlCoords)
// if you need client coordinates in RichViewEdit:
R.TopLeft := RichViewEdit1.DocumentToClient(R.TopLeft);
R.BottomRight := RichViewEdit1.DocumentToClient(R.BottomRight);
function FindControlLocation(RVData: TCustomRVData; ctrl: TControl;
var CtrlRVData: TCustomRVData;
var CtrlItemNo: Integer): Boolean;
var i,r,c: Integer;
table: TRVTableItemInfo;
Result := False;
for i := 0 to RVData.Items.Count-1 do
case RVData.GetItemStyle(i) of
rvsComponent:
Result := TRVControlItemInfo(RVData.GetItem(i)).Control=ctrl;
if Result then begin
CtrlRVData := RVData.GetSourceRVData;
CtrlItemNo := i;
rvsTable:
if table.Cells[r,c]<>nil then begin
Result := FindControlLocation(table.Cells[r,c].GetRVData, ctrl, CtrlRVData, CtrlItemNo);
if Result then
