TCustomRichViewEdit.TopLevelEditor.Format is giving error
ranjanbag
Post by ranjanbag »
I have the following code in our application. But some time "TCustomRichViewEdit.TopLevelEditor.Format" it is throwing error - "List Index Out of bounds(-1).
Could you please tell me what is the solution?
   CellData := BaseTable.Cells[CurrentRow, CurrentCol];
      CellData.Edit;
      RVData := CellData.GetRVData;
      for nIndex := 0 to RVData.ItemCount - 1 do
        if (RVData.GetItemStyle(nIndex) = rvsComponent) then
          if (TRVControlItemInfo(RVData.GetItem(nIndex)).Control is TStrikeThru) then
            if TStrikethru(TRVControlItemInfo(RVData.GetItem(nIndex)).Control).IsFromNormal then
              if not (TStrikethru(TRVControlItemInfo(RVData.GetItem(nIndex)).Control).IsFromFindingsLast) then { -ogay : added condition, so that the normals coming from load last will not return to normal state }
                TStrikethru(TRVControlItemInfo(RVData.GetItem(nIndex)).Control).Status := 0;
            end
          end
          else if (TRVControlItemInfo(RVData.GetItem(nIndex)).Control is TSmartext) then
            if TSmartext(TRVControlItemInfo(RVData.GetItem(nIndex)).Control).IsFromNormal then
              if not (TSmartext(TRVControlItemInfo(RVData.GetItem(nIndex)).Control).IsFromFindingsLast) then { -ogay : added condition, so that the normals coming from load last will not return to normal state }
                TSmartext(TRVControlItemInfo(RVData.GetItem(nIndex)).Control).TriggeredButton := 0;
                TSmartext(TRVControlItemInfo(RVData.GetItem(nIndex)).Control).MDOInvalidateSmartext;
      Editor.TopLevelEditor.Format;
      FixColors(Editor.TopLevelEditor);
      CellData.Edit;
I am afraid I have not enough information to find the reason of this problem.
Please create a simple project (without non-standard controls) reproducing this problem and send it to me.
I can see one possible problem: even after calling CellData.Edit, it's not necessary that Editor.TopLevelEditor is an inplace editor of this cell. It may be an inplace editor of a cell of another table inserted in CellData.
