TRichView, array of TGIFImage and errors on closing the form
Antinoka
Post by Antinoka »
Hi!
I use TRichView and TGIFImage for smiles in a chat. Smilies are written in Dynamic arrays. Everything works fine until smilies are not repeated. Otherwise, when you close the form see the error. Help me, please. :(
Screenshot of the error:
Source: http://kkepit.if.ua/img/Smiles.rar
  Form1: TForm1;
  GifList: array of TGIFImage;
  i: integer;
  with RichView1 do
    for i:=0 to 2 do
        AddPictureExTag('Smile', GifList[i], 0, rvvaAbsMiddle, IntToStr(i));
    ReFormat;
  for i:=0 to 2 do
      SetLength(GifList, i+1);
      GifList[i]:=TGIFImage.Create;
        GifList[i].LoadFromFile(IntToStr(i+1)+'.gif');
      except
  RichView1.StartAnimation;
initialization
  RegisterClass(TGIFImage);
end.
Antinoka
Post by Antinoka »
The error appears when you close the form when the button Button1 worked more than once.
By default, TRichView frees all inserted images.
So if you insert the same gif multiple times, the same object is freed multiple times.
There are two solution:
1) creating a new TGifImage, assigning it from the array, and inserting it in TRichView, or
2) using shared images:
 with RichView1 do
    for i:=0 to 2 do
        SetItemExtraIntProperty(ItemCount-1, rvepShared, 1);
    Format;
PS: after adding or deletion of items, Format must be used instead of Reformat.
Antinoka
Post by Antinoka »
Many thanks. The second solution I was perfectly fine. If anyone will read this, you need to add 'RVItem' in uses, if will give an error on undeclared variable 'rvepShared'.
In the beginning I did the first one, which had seen many times on the Internet, but it used a lot of memory.
  Gif: TGIFImage;
  with RichView1 do
    for i:=0 to 2 do
        Gif:=TGIFImage.Create;
        Gif.Assign(GifList[i]); // It used a lot of memory.
        AddPictureExTag('Smile', Gif, 0, rvvaAbsMiddle, IntToStr(i));
    Format;
Thank you again. :)
Actually, copying using Assign should not use a lot of memory. Delphi graphic classes use copy-on-write mechanism, so the new gif must share the image data with the images from GifList[].
But of course, using shared images in TRichView is more efficient.
