Hello Sergey
I use SRichViewEdit with the RVStytle and compile the program.
When I input something to the SRichViewEdit in the first time ,it can not display correctly and show some messy codes~!!But after I delete anything and write someting,it will display correctly!
I send the sample and screenshots
to your E-Mail
SRichViewEdit Problem
I can reproduce this problem. It happens when you assign SRichViewEdit.ExternalRVStyle, and its TextStyles[0].Unicode has a non-default value.
As a temporal workaround, call:
SRichViewEdit1.Clear;
SRichViewEdit1.Format;
