SelectAll in Table is ERROR
kisshexuxia
Post by kisshexuxia »
code in SRichViewEdit1.ONkeydown
  if  ( ssCtrl in Shift ) and (Key = ord('A')) then
      ActiveEditor.RichViewEdit.SelectAll;
When I Move Mouse in Table,then press ctrl+a TO SelectAll is ERROR
But when Mouse not in Table then press ctrl+a is OK .
please help me
TRichViewEdit does not allow destroying a cell inplace editor inside OnKeyDown event (unfortunately it cannot be fixed because of VCL design).
Any method that moves the caret outside the cell, including SelectAll, destroys the cell inplace editor, so it cannot be called from OnKeyDown.
Solution:
1) (recommended) use an action or a menu item with Ctrl+A shortcut
2) Use PostMessage with a custom message to call SelectAll not in OnKeyDown, but after. Let me know if you need an example.
kisshexuxia
Sergey Tkachenko wrote:TRichViewEdit does not allow destroying a cell inplace editor inside OnKeyDown event (unfortunately it cannot be fixed because of VCL design).
Solution:
it's OK use an action with Ctrl+A shortcut.
my code in OCX then the up,down,left ,right. is not work
What version of TRichView do you use? Newer versions have some changes fixing problems in OCX.
PS: making OCX requires a special permission from us.
It's OK if it is made for a private use or use inside a company.
If it is made for a public access (from web or as a part of your application), it is normally OK too, but we need to know details.
It's not OK if this OCX is used in development environment by people who are not registered TRichView users, it requires a separate license.
kisshexuxia
Sergey Tkachenko wrote:What version of TRichView do you use? Newer versions have some changes fixing problems in OCX.
my version SCALRICH4.6.1
RichViewv13.10.1
it have registered
i have a other version
Richview13.11.1
SCALRICH4.7
what version have some changes fixing problems in OCX
Download newest versions of TRichView, RichViewActions and ScaleRichView from the same links as you received when registered.
The newest version of TRichView is 13.13, SRV 4.8.
If the problem still exists, please send a simple project reproducing it to richviewgmailcom
kisshexuxia
Hi Sergey Tkachenko
I try to new versions of TRichView is 13.13, SRV 4.8.
It¡¯s error too.
I write a demo
1. Click button to open form2,when only open one form2,the popupmenu is right,but key left,up,down,right is not work.
2. when open two form2(click twice open button ),don¡¯t close one , the popupmenu is¡¯t work .
I put a time to made to work but it error in new versions(in ocx and dll the dmActionsSRVAlpha don't work)
SRVGetRichViewEdit don¡¯t in SclRView.pas
3. when the focus on second form I uses popupmenu paste(don¡¯t use CRTL+V), but the content is on first form
In the new version of ScaleRichView, the code
RVA_GetRichViewEditFromPopupComponent :=
   SRVGetRichViewEditFromPopupComponent;
  RVA_GetRichViewEdit := SRVGetRichViewEdit;
is not needed - delete it.
You can find updated ScaleRichView ActionTest demos here:
http://www.trichview.com/rvfiles/scaler ... _demos.zip
Please send me a project reproducing problems to email richviewgmailcom (insert @ and .).
kisshexuxia
Sergey Tkachenko wrote:Hello,
I Has been sent to you
but i don't know how to modif this demos
type
  TrvActionAccess = class(TrvAction);
function TForm3.GetRVAControlFor(Action: TAction): TControl;
  if Action is TsrvAction then
    Result := SRichViewEdit1
  else if Action is TsrvAction then
    Result := SRVGetRichViewEdit(SRichViewEdit1.RichViewEdit,
      TrvActionAccess(Action).RequiresMainDoc)
    Result := SRichViewEdit1.RichViewEdit;
procedure TForm3.Timer1Timer(Sender: TObject);
var i: Integer;
  for i := 0 to srvActionsResource.ComponentCount-1 do
     if srvActionsResource.Components[i] is TAction then
       TAction(srvActionsResource.Components[i]).UpdateTarget(GetRVAControlFor(TAction(srvActionsResource.Components[i])));
procedure TForm3.DoActionsExecute(Sender: TObject);
  TAction(Sender).ExecuteTarget(GetRVAControlFor(TAction(Sender)));
In FormCreate:
      TAction(srvActionsResource.Components[i]).OnExecute := DoActionsExecute;
[/quote]
function TTest_OCX.GetRVAControlFor(Action: TAction): TControl;
    Result := srv
     [color=red]Result := srv.RichViewEdit.SRVGetActiveEditor(TrvActionAccess(Action).RequiresMainDoc)[/color]
    Result := srv.RichViewEdit;
kisshexuxia
    Result := srv
THANKS
the error in OCX ,please help me thank you very much
I found the solution in the Internet. Here it is with some modifications:
In TTest_OCX declaration:
    function OCXKeyEvent(var Message: TMessage): boolean;
    procedure WndProc(var Message: TMessage); override;
Implementation:
procedure TTest_OCX.WndProc(var Message: TMessage);
  if not OCXKeyEvent(Message) then
    inherited;
function TTest_OCX.OCXKeyEvent(var Message: TMessage):boolean;
var msg: TMsg;
  result := true;
  case Message.Msg of
    WM_GETDLGCODE: begin
      Message.Result := DLGC_WANTTAB or DLGC_WANTARROWS;
    WM_CHAR: begin
      if Message.WParam = 9 then
        srv.ActiveEditor.InsertTab;
    WM_KEYDOWN: begin
      if Message.WParam in
        VK_LEFT,
        VK_RIGHT,
        VK_UP,
        VK_DOWN,
        VK_TAB,
        VK_HOME,
        VK_END,
        VK_INSERT,
        VK_PRIOR,
        VK_NEXT
      then begin
        msg.hwnd := GetFocus;
        msg.message := Message.Msg;
        Msg.WParam := Message.WParam;
        Msg.LParam := Message.LParam;
        Msg.time := 0;
        Msg.pt := point(0,0);
        DispatchMessage(msg);
    end
    result := false;
kisshexuxia
thanks It's OK to press left,up, down,right.
But the RVAPopupMenu still work error,when I open two form2 and work on the second form2 . copy ,cut,paste is't work on the
RVAPopupMenu. When i press paste (RVAPopupMenu),it paste on the first
form2.i find when i open two form2 ,it error.
By default, all actions works with the focused editor. So all buttons and menus in inactive forms work with the editor on the active form.
I assume that you have TRVAControlPanel on the form, with DefaultControl property assigned. In the new version of RichViewActions, the first created RVAControlPanel becomes default, so in this case all actions will work with the first created editor.
I suggest making the following changes:
1) Create only one copy of srvActionsResource (in the code you send to me, you create a new copy TTest_OCX.ActiveFormCreate each time; change the code to create srvActionsResource only if it equals to nil)
2) Do not place TRVAControlPanel on TTest_OCX. Place it on this datamodule instead. Do not assign RVAControlPanel.DefaultControl.
3) Remove ActionList from the datamodule and insert it in TTest_OCX form instead (cut to the Clipboard and paste).
4) Change the code in TTest_OCX.ActiveFormCreate to:
  for i := 0 to ComponentCount-1 do begin
      if Components[i] is TsrvAction then
        TsrvAction(Components[i]).Control := srv
      else if Components[i] is TrvAction then
        TrvAction(Components[i]).Control := srv;
      if Components[i] is TAction then
        TAction(Components[i]).OnExecute := DoActionsExecute;
5) Change the timer code:
       TAction(Components[i]).UpdateTarget(GetRVAControlFor(TAction(Components[i])));
kisshexuxia
kisshexuxia wrote:Can you send me the DEMO what have modified
I try to modif the code
1.
if not Assigned(srvActionsResource) then
       Application.CreateForm(TsrvActionsResource, srvActionsResource);
2.replace
3.Remove ActionList1 from the datamodule and insert it in TTest_OCX form instead (cut to the Clipboard and paste).
4.modif the RVAPopupMenu1.ActionList to ActionList1.
it show class TsrvActionExport not found
