I managed to install the non-DB package but I am having issues with the RVDBPkgXE2.bpl package installation.
In the beginning, it failed the compile because it was unable to find the designintf.dcu file and I added the 'designide.dcp' under 'required' and that did part of the job.
After which, I attempted to Build and I got the following error
[DCC Error] RVDBDsgn.pas(70): E2003 Undeclared identifier: 'RegisterComponentEditor'
[DCC Fatal Error] RVDBPkgDXE2.dpk(42): F2063 Could not compile used unit 'RVDBDsgn.pas'
I am not sure how to proceed from here. Hope you could share your insight to this issue.
Install Issue with RVDBPkgXE2.bpl in XE2
It's not possible to install 64-bit packages in RAD Studio, because RAD Studio itself is 32-bit application. Only 32-bit packages must be installed.
Install RVPkgDXE2 as it is, as a 32-bit package.
Once installed, you can create both 32-bit and 64-bit projects with our components (the first compilation of the project must be "build all", to recreate dcu for the project's platform).
