Hi Sergey
I have email application based on RVE editor.
I write some text and insert a signature image by using:
rve.LoadRTF(GlobalUserPrivateDir + '\signature.rtf');
rve.Format;
I save to html using:
rve.SaveHTML(EmailTempFile, '', 'img', [rvsoOverrideImages,
rvsoOverrideImages]);
what i get in the recipient inbox is this:
<html><head><title></title>
</head>
<body bgcolor="#ffffff" leftmargin=5 topmargin=5 rightmargin=5 bottommargin=5>
<font size=2 color="#000000" face="Arial">
<div dir=RTL>This is line 1</div>
<div dir=RTL>Roni Lev</div>
<div dir=RTL><img width=576 height=144 hspace=1 vspace=1 src="C:/Users/roni.TEVELSOFTWARE/tevel/TEMP/img158.gif"></div>
<div dir=RTL><font size=3 face="Times New Roman"><br></font></div>
</font>
</body></html>
<P><FONT SIZE=2 FACE="Arial">No virus found in this incoming message.<BR>
Checked by AVG - www.avg.com<BR>
Version: 9.0.930 / Virus Database: 2437.1.1/5161 - Release Date: 07/28/12 21:34:00<BR>
</FONT></P>
The image is not diplayed
any idea how to do ir right
Roni
sate to html
Yes..
this is the exact lie (taken from your samples)
rve.SaveHTML(EmailTempFile, '', 'img', [rvsoOverrideImages]);
this is the html in the file before i send it:
<meta http-equiv="Content-Type" content="text/html; charset=Windows-1255">
</head>
<div align=right dir=LTR><br></div>
<div align=right dir=RTL><img width=576 height=144 hspace=1 vspace=1 src="C:/Users/roni.TEVELSOFTWARE/tevel/TEMP/img160.gif"></div>
<div align=right dir=RTL><font size=3 face="Times New Roman"><br></font></div>
</font>
</body></html>
Roni
</head>
</font>
</body></html>
Roni
This is very strange.
By default, images are saved with autogenerated names. With the parameters 'img' and [rvsoOverrideImages], TGifImage must be saved as <img src="img1.gif"> (assuming that you called RV_RegisterHTMLGraphicFormat(TGifImage) before saving), and img1.gif must be created in the same directory as HTML file.
But <img src="C:/Users/roni.TEVELSOFTWARE/tevel/TEMP/img160.gif"> looks like rvspImageFileName was used, and the image file itself is not created (it is assumed that it already exists). However, rvspImageFileName is used only if rvsoUseItemImageFileNames is included in the Options parameter of SaveHTML.
So I am puzzled.
Please send a sample project reproducing this problem to richviewgmailcom.
So I am puzzled.
