Hi team,
How can i use a combobox in TSRichViewEdit ?
I need it to fill out a textfield or as a lookup in a table-cell.
Additive I have to check the kind of field because I must support
minimum 16 several comboxes but I want, that only the current is visible.
Have you a example for this topic ?
Regards
Andy
Lookup -> combobox: Used for Input in Table or on textfie
You can use TSRVComboBox (included in SRVControls), other comboboxes do not work properly in TSRichViewEdit.
To hide/show a control, use rvepVisible property: http://www.trichview.com/help/idh_type_ ... perty.html
